Originally Posted by
the Wasp
Lonnie. I was not looking forward to honing the cylinder. thinking, and knowing it should be done as correctly as possible. how would I do it I asked myself. it hit me. I have 400 grit DA sandpaper and EXtra sticky doubled sided tape. put the two together, clean and dry my finger with Denatured alcohol. it should stick good to my finger so I should have good control over the sandpaper with my finger. I will first try it on the old cylinder. if it works I will do it on the cylinder I got from you.
Jim
Jim, I didn't look at the cylinder wall with high magnification but just using my reading glasses and a flashlight it looked new enough to not need honing. I doubt the cylinder saw more than 2 gallons of fuel. A new RMJ ring and some run time should make it a winner.
