Originally Posted by
Jesse Open
Dave,
IIRC the 62 carb is also used on the 65, the spraybar for the 80 should be the same as well.
Like Lonnie says, those lists are not always complete.
I have ordered all of my Saito parts from MacGregors for some time now. Horizon has become a place I will not deal with.
Yes, I remember well when almost every four stroke at the field was schmutzed up with that silicone crud!
Yes, on the third/last version of the 65. The first two versions used that wonderful true fuel metering carb with the tear drop fuel passage at the end of the throttle barrel. I wish that all Saito carbs were made that way.
