Originally Posted by
J330
Charging inside the battery with nimh isn't a problem when using a nimh charge program on your charger at 10% of the packs rated mah (say 3000mah) you can drive 300 milliamps through the charge jack. It has no issues doing that with any brand nimh battery. The nonsense that one brand being special is completely nonsense. Nothing supports such wives tales anywhere on the internet. Eneloop charges exactly the same as any other nimh brand, it's all about capacity and charging at 10%. Yes you can charge at that 10% rate, as long as you never exceed 900 milliamps while charging, exceeding the capacity of the wiring inside your radio.
If you charge a lipo, or LiFe battery, you can charge over 1 amp and that would require removing the battery from the radio.
Avoid answers from non-technical individuals, it can mislead you. You can confirm a valid statement through google, any battery manufacturer, and that includes Eneloop distributors.
Why don't you just give a newbie a simple yes/no answer instead of complicating his choices by denigrating other posters with technical data he's not interested in?
