1st with everything plugged in and switch on, if you hit the spool button does the turbine spin over? Over Current is exactly what it says, but it means something is (or thinks) it’s drawing 20-30A !
Normally it’s the red/yellow/black cable, I presume it’s got the yellow end with 90 degree plug? If not order new leads and toss the original in the trash
