[QUOTE=BarracudaHockey;12754329]Oh....geeze it's been so long, if I were setting one up right now without a manual I'd probably max out the throws and set about 25% expo, and have a low rate of about 70 percent of full throw. Those live hinges on that thing don't have enough room to give you scary throw even if you max them out.
The CG mentioned above is spot on, that 90mm crap in the manual, i ran out of elevator trying to flare the first flight and got "doing carrier landing" cracks from the peanut gallery.[/QUOTE
I’ll try that thanks again
