Originally Posted by
mdiesu
Thanks for your input. This is my first time also to use the treaded EZ Connecter. I'm using them on the Ford Trimotor. This is a short kit, which needed many modifications. It will be some time
before it is ready to fly. I used the loctite also, but very carefully pained the thread area. I installed the connecter with a lock washer, snug and then backed off slightly. I carefully rotated the connecter and the servo arm a number of times to make sure both were not bound. My biggest concern is the rudder connection. When all goes wrong by controlling the rudder you a chance to avoid a crash.
