You could try but the ignition should work at 6.1V. If it requires more voltage then that it is defective and will eventually fail completely. It’s also possible that if your plug gap is too large for the ignition not to work at lower voltage, or plug cap is not installed correctly. Those two things are a shot in the dark but worth looking at.
