Originally Posted by
Clugh
I wonder how effective the mid wing is on the Eagle considering it as not a complete to trailing edge aero foil? We also plan to test some hall sensored out runners with the XLX2 . We want to see if we can utilize smart sense and cryo drive technology from castle on the outrunners but these 2 boats I build will be full Neumotors and Castle Creations nothing else.
Regards
Hubert
And so with one of the outrunners on the motor mount end will have this mounted on the shaft and print a fully adjustable rotating bezel that hold the 3 hall switches 30 degrees apart that will observe ROAR hall wiring to a JST connector just like the car in runners.This one came from a BOSCH window drive.
The adjustable then lock down rotating bezel will allow me to statically adjust timing as well.
