If you are going to use the Jeti built in gyro do lots of ground testing the Rebels I have seen with that twitched and jittered because of the turbine emf.
I have 2700 2s li-po in the nose, the two 1350. 2s Li-Po Rx packs next to the tank and a 800mAh 2s Retract pack in the turbine opening.
