I've started the assembly of the parts I have cut out so far. In order to make sure everything is in alignment I have put together a jig to make sure the spars are parallel.
Unfortunately, the washout I was attempting to put into the wing worked out to be at 0 deg to the root instead of the 5% I was going for so I'm going to have to tear it down to the fuse formers and try again. To the good several things I overlooked in installing the ribs I can now correct.
John
