Originally Posted by
LLRCFlyer
... data on this motor such as maximum continuous allowable amps or watts ...
Conservative rule of thumb for max. continuous motor power: 4watt per gram motor mass.
A safe starting point.
You already have the
velocity_konstant_Kv
Note that Kv says nothing about a motor's
maximum power, both the motor in your toothbrush and the motor in e.g. a 1:1 train can have the same Kv.
However, Kv has a massive effect on actual current and power
drawn, both are proportional to Kv cubed.
E.g. doubling Kv, would 2³=eight fold current and power.
Some expensive realistic
and some extremely silly
examples, hopefully instructive as well.
Therefore always check/measure currentdraw in a new/changed setup.
LLRCFlyer
... max voltage? ...
Motors can any voltage in RC land, as long as current, power and rpm don't get too high.
The wire insulation/lacquer/resin/coating can withstand several hundred volt.
LLRCFlyer
... Is anyone else experiencing slung magnets with this motor? ...
Method for securing the magnets afterwards, as an extra precaution.
Also describes a method for epoxy heat treatment to increase glue maximum temperature:
old.torcman.de/motoren/manuals/manuals_e.htm
→ Assembly Procedure TM280, 350, 430
→ 3.2 Filling the magnet spaces
LLRCFlyer
... Flex does not list any physical or performance data ...
Lucien Miller knows powersystems, they test their motors themselves, you can take their numbers to the bank, excellent propcharts. Not the usual nonsensical heap of voltages and propsizes.
www.innov8tivedesigns.com and
www.badasspower.com
Prettig weekend
Ron
• Without a watt-meter you're in the dark ... until something starts to glow •
• E-flight calculators • watt-meters • diy motor tips&tricks • Cumulus MFC •
