I fired up the little lathe pictured above and made an offset adapter for Saito 125 so I wouldn't have to run the throttle cable over top of the fuel tank. I still need to drill and tap for the inboard grub screw. Both ends are a snug slip onto the carb barrel and into the throttle arm.
Reason: Add comment
