Hi all,
And here is the final installation !
Wrapped that childish, multicolored turbine cable with some black, flex net protection tubing
Then I exchanged the tygon tubing on the smoke pumps pressure side to PU tubing - much better ! No tygon on the pressure lines they say !
Everything concerning the turbine has been run ( say pump, starter, valves and the 2 burners ) and all systems work flawlessly !
So, next will be weight and balance ( easy with Toms templates ) and then out to the flight line for live system tests and taxi runs - I never do a maiden upon the first outing !
see you
Hans
