Gents,
I just got the atom and starting to change all my jets over from spectrum.
I'm setting up a new Rebel Pro with Jets munt 210. How is every setting up their turbines?
I managed to get the right pulse settings by going into Functions-Throttle-Trim as per photo. This ok or should I change it?
This is from the Jets Munt manual.The setup assumes the use of a transmitter with manual trims. If you use a TX with digital trims, is essential to use the switch in the TX programmed for the function "Throttle cut", or “engine cut” which normally has the effect of producing the “trim-down” function. Using a digital trim cause unstable idle, and delay in shutting off the engine in emergency. Check your radio manual for this before you start. Avoid using the digital trim if possible.
