AS630/AS3X problems
To continue the saga, I discovered that the receiver, after resetting, worked fine. but two servos and the speed controller were burned out, now replaced, and I have completed the initial setup.
First flight was disastrous as I accidentally set high rate on elevator! All now repaired but not yet reflown.
Thanks Andy for your help, I will play the video multiple times to try and understand it, but am not optimistic as it says that at least one spare channel is required, and and all six channels of my AR630 are already used.
Strange - as my old E-flite Spitfire had all the same functions as the Durafly Spit and was factory fitted with a six channel AR636 receiver with working AS3X.
So I might have to buy a 7 or 8 channel receiver?
