RCU Forums - View Single Post - TongDe / DKLM M60A2 "Starship" build.
Thread
05-26-2023, 02:52 PM
12
Fsttanks
Finished installing flash and IR bulb and moved on to testing turret function. Then installed the mantle cover. The one thing I was truly dreading. It ended up not being so bad just TIME consuming.
Video of test firing of main gun was posted to my Instagram @ Fsttanks if you would like to see it.
Testing flash LED.
Installing mantle cover.
Installing mantle cover. A little trick I figured out was to slightly enlarge the screw hole and depth. Made it much easier to work with the tiny screws.
Almost done. About two hours work at this point.
Finished and excess material has been removed.
Front view.
Dry fitted to lower hull.
Reply
Like
bowlman
(05-27-2023)
Fsttanks
View Public Profile
Send a private message to Fsttanks
Find More Posts by Fsttanks
View iTrader Profile
