That liner has definitely peeled, but because it was around the exhaust port you were probably able to continue running it without having any running issues. I’ve included a photo of of peeling from one of my old liners, where the peeling occurred at the top of the liner which will impact the low end first (reliable idle rpm increases). Also, unless you are running sealed bearings, the flaked nickel will ruin the rear bearing.
