Carbon Cub problem!
I am a newbie to the sport of RC flying. I have been flying an AeroScout for a couple of months now and am able to fly it well, take off and land decently. Then I bought a Carbon Cub. OMG! I can't get it off the ground in any reasonable semblance of a takeoff! I switched to the landing gear modification using the Valiant gear. That didn't help much. I start to slowly increase the throttle and when it starts to go to the left I add a bit of right rudder. This works for a second or two and then it turns sharply to the left. This happens in a split second and there is no time to react. I have been told the wheels are toed in, then that they are toed out, then that they are not both in line, then the tail wheel is not straight. I had one of the really good fliers that flies jets fly my cub and he managed to get it in the air, but the takeoff wasn't pretty by any stretch of the imagination. Okay, so I figured out something to insure that the wheels were both in line with no toe in or out and strong enough to prevent any bending. What I did was use a 1/8" diameter rod for a common axle for both wheels. It goes through two holes in the Valiant landing gear mod. In between the two legs of the Valiant landing gear the 1/8" rod goes through a 1/8" diameter hole in a carbon arrow shaft. This provides rigidity for the axle and prevents the aluminum arms of the Valiant gear from bending. Then I bought 3" wheels to replace those huge wheels that come on the Carbon Cub. You can't use this if you fly on grass, but it should work fine on pavement. I tried it out today and it is rigid and keeps the wheels in line, but the plane still does that sudden whoop-d-do with no warning! I stood directly behind the plane on takeoff and could not see any advance warning of that sudden 180 degree turn! It is downright scary and a bit dangerous!
CAN ANYONE HELP ME? I AM AT MY WITS END!!
