RCU Forums - View Single Post - Starting out and building ?'s
Old 11-17-2003 | 02:13 PM
DrFun's Avatar
DrFun
Default RE: Starting out and building ?'s
After my ARF trainer I build my first kit.
Go ahead and build one covering is not difficult, here is what I did for my first kit/covering and came out good. I was also afraid of covering, see MinnFlyer's article on how to cover and will help a lot.
http://www.rcuniverse.com/forum/m_11...tm.htm#1120607
You don't need to practice covering in my opinion, but I used a scrap balsa sheet and played with it for a while with covering and iron.
Only think to be carful is heat gun, you can remove wrinkles very easy with it but there is a certain amount that you can remove after a while you can easily put a hole in the covering. Done that on my first wing and learned.
First kit is a great way to learn.
