RCU Forums - View Single Post - Hovering and right thrust
Old 05-11-2002 | 01:56 PM
GASTANK
Default Hovering and right thrust
Well all the advice given to this post sounds good on paper ,However in the three years needed to prefect the hovering gig I've found that only the V E R Y overpowered planes Such as the profiles with 91 Satio or to that efect will be a problem. The continuios throttle transition will cause the airplane to torque over to the left. When you get more experence it's a great lesson to remove all the thrust and even set the airplane up a little nose heavy. In other words (remove the tranning wheels). Hope this helps... DAVE
