RE: F3A Formosa ARF Park Flyer GWS
Mxwrench,
I have a Formosa and I'm about to build it and I wanted to check with you regarding any suggestions you might have regarding the building.
I've just ordered the same motor, gear box, and propeller but with a different controller.
Did you ever find out what was causing the "up elevator"? Would you recommend a little "up" thrust in the motor mount?
What adhesive do you suggest? I heard the the GWS glue is not that good and that epoxy adds a lot of weight. I was thinking of using epoxy for the motor mount and wing hold downs, but carpenter's glue for the rest - what do you think?
Any suggestions would be greatly appreciated.
Best regards,
Wayne Miller
