RE: V-one RR gearing help
stay with the stock pulleys - they are the best out there. also stick with the stock spur gears. I run a trinity reflex, which is basically the same car as a V1RR. I run a 16/19 pinion set on small tight tracks, and 18/21 on larger tracks. i wouldnt go any higher than a 17/20 on the OS .12TR, since it lacks the bottom end power needed for anything higher.
