RE: elevator feels realy stiff
Did you stick a T pin in the middle for propper spacing? If you have them too tight they will bind too, they require a small gap to work as freely as they are supposed to anyways. Also, make sure you dont have any excess epoxy on the center joiner wire between the elevators, this would cause some binding as well. Good luck.
Brian
