RCU Forums - View Single Post - Time to get wet.
Old 11-26-2003, 02:57 AM
pro27
Default RE: Time to get wet.
There is always a time to use the right product!
All my small (1/2A) airboats are design/idea test beds. They are cheap and fast to build, cheap to equipt, cheap to run, but are still a lot of fun.
I use the plastic covering on all my small boats for a couple simple reasons.
It's fast . And I consider the boats expendable. They are design tests after all.
Also with the covering, if I want to make a modification, I don't have to sand down paint to get glue to stick, a quick slice through the covering, a little heat and peel it off.
If the small boat makes it through the testing stage, well then, I have another fun boat.
Don't get me wrong, the covering is durable, but not as durable as a good hard coat finish.
If I hit the same pipe you did, I'm sure you would be able to tell.
