Originally posted by rcflier_gi
My Ultra Stik 1.20 is a bear to knife edge without mixing. If I mix 22% opposite aileron and 12% down elevator it will hold a knife edge with rudder alone.
rcflier_gi,
I have an Ultra Stick 40 and I'm going to mix ailerons and elevator as you've done to try and improve its knife edge. For starters I'll try the 22% & 12% that you've suggested (even though I have the 40 size).
However, I was curious if you use straight 22% & 12% values across the entire ruder throw range or if you use (or have tried) variable percentages (exponential) so the percentages change depending on how far you move the rudder.
KeithB
