RCU Forums - View Single Post - flair technique
Thread: flair technique
Old 02-28-2003 | 01:19 PM
ballgunner 's Avatar
ballgunner
Default flair technique
The only way any airplane whether 1' = 1' scale or otherwise, will stay on the ground is if it has stalled and can no longer fly. When you get close to the ground, 6" or so, try your best to keep the airplane flying with the elevator, assuming you are already at engine idle. When it decides to stop flying you will be on the ground.
