RE: Aileron and Elevator rolling circle's ?
The best way to learn one is to use the following set-up and procedure:
-Aileron and elevator only at first.
-A slower roll rate will let you learn to coordinate the elevator more easily. Set a very low rate aileron, slow roll speed.
-Roll and turn in the same direction at first.
Once you get the coordination down, you can increase the roll rate and add in rudder, if necessary.
