RCU Forums - View Single Post - Small parts including belt drive parts
Old 12-11-2003, 11:50 AM
notasme
Default Small parts including belt drive parts
ALL,
Anyone looking for gears, belts or belt drives. Should check out this site https://sdp-si.com .
You can find replacement gears and gears that can be used to change the gear ratio. You can also
build you own belt drive with the same 1:2.8 ratio or make up one you want to try.
You could also do the same if you are using the gear drive and you can get the gears in brass or steel.
