Engine Tuneing , How hard is it?
Sounds like the top end is too lean.
Open the main needle, reset idle and try again. I say lean because you are blowing plugs.
Does it acutally hover? You say mid-range is OK, but also say it has no lift at the top end. Mid-range is usually defined as hovering power in helicopters, top end is for max. pitch climbouts.
