RCU Forums - View Single Post - Throttle linkage?????
Old 12-16-2003 | 03:25 PM
P-40LUVR's Avatar
P-40LUVR
Default Throttle linkage?????
I just set an OS70 FS in a Kyosho p-40 and it is mounted inverted..now...the thottle arm on the engine is setting right in front of the hole in the firewall where the fuel tank tubing comes out..i have to figure a way to hook a throttle linkage that comes out of the firewall off to the right so that the linkage going back to the servo is not interfering with the fuel tank.
If i bring the throttle rod up and off to the right of the arm on the engine how can i get it to move the carburator on the engine..
Any suggestions are welcome.I can't use the Ubend method because the control rod would have to go straight back which would hit the fuel tank in behind and there is not enough room around the arm off the carburator to move forward and back as you can see in my pic.
