RCU Forums - View Single Post - Throttle linkage?????
Old 12-16-2003 | 08:45 PM
CafeenMan
Default RE: Throttle linkage?????
It's kind of ridiculous how O.S. set these up. I can't figure out how they expect us to hook up a linkage. If using an EZ connector, then you have to have access to the set screw and that may not be possible if the cowl is built into the fuselage. If using a Z-bend, then there's no way to hook it up. If using a clevis or ball link then there's not room for it to move without hitting the firewall.
