Old 12-20-2003, 09:37 PM
NOVAflier
My Feedback: (21)
NOVAflier's Avatar
Default RE: ultra stick 60
The engine should be mounted at a 90 degree angle, meaning that the throttle will be facing up, and looking down at the top of the plane, you will see the side of the Saito. Then, you can rotate the carb 180 degrees, I think there is a small scew on it that holds it and you can rotate it into position.. Let me see if I have a photo..
