RE: Affixing Aluminum To Fiberglass
It's called Goop and you will find it at any hardware store and most retail stores as well, it comes for different applications, but to me, they are all the same, just marketing hype, the regular one for household use is the one that I use the most, it will stick to anything with a vengeance, because it is heavy and because it works so well, use very little of it, small dabs here and there work very well, an entire surface doesn't need to be treated, test it first so you see how it reacts, spread some with your finger and see how much fun it is to pry it off your skin, no kidding, it's fun! I haven't seen Gorilla's Snot, but I do use Goop to fix the soles of my Sneakers when they start to come unglued.
