Old 12-27-2003, 09:47 PM
TLH101
My Feedback: (90)
TLH101's Avatar
Default RE: v tail. how do you steer nosewheel?
There may be an easier way than this, but I would not mix with the transmitter. I would use a separate V-Tail mixer. Then you can use a Y-harness in the rudder output, with one connector to the nosewheel servo, and the other to the mixer. This will isolate the nosewheel servo from the elevator output. You will also need plug the elevator to the mixer as well. I am sure this can all be done with transmitter, and some mixing, but I cant seem to figure it right now.[sm=spinnyeyes.gif]
