Old 12-28-2003, 01:09 PM
Tall Paul
Default RE: v tail. how do you steer nosewheel?
If you have the rudder and elevator on the right stick, then the seperate steering servo on the rudder channel works well. Use the elevon mix, not the rudder-elevator..
upper photo.
The vee-tail in the lower photo has the tailwheel attached to the flying tails with springs..
ID:	85740   Click image for larger version
