gas take placement
i just bought a used Magnum XL 61 from a friend. It has never ran that well. But now it will not run at all. The engine is inverted and i know 4 strokes are more difficult in that position. My question is how important is it that the tank be lower than the needle valve? it's pretty close but it is higher. Should I consider this part of the problem. The engine is just not sucking fuel. The tank is airtight and all the engine bolts are tight. could this be part of it?
thanks
