RE: Building Giant scale Question
Be careful if you use the copier method to transfer the pattern. Most copiers change the size a small amount, so compare the copies to the original. I usually have the plans reprinted at the correct size, then cutout the part patterns. I put a lite coat of spray contact adhesive on the pattern and stick it the wood. You can remove it very easy and reuse the patterns.
