RE: U Cant Do good Elevators? Try Spoilerons!
I just got a 9C for christmas. If I read the book correctly, you can set the spoilerons to become active with a preset ELEV position. In other words it can be set it to kick the spoilerons in @ 90% of elevator stick movement. Will have to experiment with it once it's in the plane. You guys might also try putting a piece of fuel line on the switches you use the most. It makes them a lot easier to find.
David
