Old 12-30-2003, 12:51 PM
Flypaper 2
Default RE: ap.09 running problems
Make sure the tank is as close behind the engine as you can get it. Hold the nose up and set the carb till the engine peaks. back the needle out till you can hear it noticably slow down, then try it. Don't forget, as the fuel level goes down the engine keeps leaning out. The engine should be at peak RPM by the time tank empties. To big of a tank can make the problem worse.
