RE: servo leads "crash"
hi thanks for the replies,the leads were all nice and secure,battery was used again as was the switch, in the smaller plane ,must admit to not range checking with engine flat out opps.am doing some tests tomorrow so will try every thing ,something has come to mind that the ailerons kept flicking to the right badley.weather permiting i will try loads to get it to go wrong before plane gets up.
battery 1100mah newish
futaba pcm new
crystal new
switch new
leads and servos new
poor plane r.i.p new
is this battery ok ? mmmmmmm await your verdict
