RE: Help Please.... I've been beat up by props....
I have a reamer but it only goes to 12mm. I can't find one at 13.5mm (17/32). This may be a dumb question but do you ream it by hand or use a drill press? I may try using the reamer to 12mm then finishing off with the 17/32 bit.
Oh, it's not the spinner, I haven't even got that far yet. I'm just trying to balance the prop.
Doesn't anyone know if you can buy a already balanced and drilled prop for this application?
