I am currently building my first indoor plane and I was wondering what is the best method to attach the motor and gearbox to the plane. Currently I'm building a GymSwallow using a GWS IPS-A motor/gearbox. Should the motor be glued on with CA, or should I use hotmelt or small screws? I'm not sure what would be the lightest method.
I'm also wondering on the best method for attaching landing gear to the plane. Would a tiny amount of epoxy be best? The plane can be found at
http://www.tdmsoftware.com/majewski/...f/swallow.html
What are your guys thoughts?
