RCU Forums - View Single Post - Webra 32 Problem
Old 05-20-2002 | 07:21 PM
miderror
Default I've had that happen
In my case it turned out to be a pin hole in the pick up inside
the fuel tank. Wouldn't show with the plane held nose high
but kept showing up on pull ups to vert. Guess it was the G's
on the tank pulling down on the line. Anyway changed the line,
after trying plugs, needle settings,fuel,head shims,etc.
Problem solved.
Maybe you have the same problem?
