RE: Critical angle of attack...
The AOA has a border of a dive or a stall.
You adjust it in the air with the elevator trim.
I dont see any means of calculating it in the air, other than eye sight. All the tech info is usless to you if you build a kit, and not needed.
Incidence is used to set the AOA when building, but not adjustable in the air.
