RCU Forums - View Single Post - Getting Back in
Old 01-03-2004, 02:18 PM
spokman
Default RE: Getting Back in
Ditto for what everyone else said. I wouldn't want to get shot down either but if you're in the boonies go for it. As far as building a strip this is going to be tough. You'll need some equipment to do it. I would research how grass runways are made for real planes. It will have to be smoothed with some type of equipment. Maybe a grader depending on how bad it is then you might be able to drag something such as a large grate or wire mesh with weights behind a four wheeler or truck to furth smooth it. Then there is grass planting. Might want to check with a local grass seed/turf company to see what they recommend. G'luck!
