RCU Forums - View Single Post - G45 Muffler Stack
Old 01-05-2004 | 12:48 PM
Bax
Default RE: G45 Muffler Stack
Some things to check:
If you're running the rubberized gasket between the engine and the exhaust header, this can cause flexing as the engine vibrates. We usually don't use the gasket.
You might also want to see if the mating surfaces of the exhaust stack or the header are good and flat. If they're not, then some stress is being put onto the header when you tighten it onto the engine.
