RCU Forums - View Single Post - Flexible exhaust pipes?
Old 01-05-2004, 10:31 PM
moparcolt
Default RE: Flexible exhaust pipes?
Well, here's what I ended up doing. I bought a saito fleh pipe and ran it to the pitts style mufler that I made and I'm going to attach it to the muffler with a small hose clamp and coppper silicone. I'm going to cut some small slots in the end of the flex so it will clamp down on the muffler I may try it first to see if it will seal up without the slots because the fit is pretty tight.
The muffler is out being ceramic coated so I have to wait till it comes back.
The flex is only a couple of inches long so it should hold up ok, there are no tight bends ,so that should help.[8D]
