RCU Forums - View Single Post - ace simple series ultimate
Old 01-06-2004 | 12:32 AM
acropilot_ty
Default RE: ace simple series ultimate
Changing the incidence wont change the stall speed, it'll just change the speed that it will lift off and land at in 3 point attitude. The lift off is the only one that is fixed since you can't force the main wheels into the air with up elevator to increase the angle of attack during takeoff... however, takeoff isn't usually a problem as far as field length, and the landing roll won't be affected by changing the incidence.... You can simply land tail first instead of 3 point. Another option is to use larger tires or longer gear legs to increase the attitude sitting on the ground instead of changing the incidence of the wing with relation to the fuselage... same net effect with no bad side effects to the aerobatics that would result from changing wing incidence.
Ty
