Old 01-07-2004, 07:21 PM
Azcat59
Default RE: New Wing, Flight Trimming problems!
This tells me that you took off with the right aileron drooped some, which helped bank the plane left. Note your flying trim position on the TX, then move it back to neutral, and see if this isn't what happens. Now the fix....you need to have the left aileron down slightly (about half of what it was after you landed) and the right aileron up about the same amount. This with your TX trim in neutral. Now fly, and use the trim tabl to clean up any slight difference.
All of this is probably happening because you have a slight warp in the wing, which you may or may not be able to take out, depending upon the strength of the structure, etc. Try the above fix first and see if that doesn't get you back in business.....
Clair
