ORIGINAL: hoppy
Ok, I'm about ready to blow a gasket.... Where can I puchase props that are pre-drilled, pre-balanced for a tru-turn spinner on a Moki 2.1?
I want to puchase a 20 x 10 prop that will fit the above application. Any suggestions please?
You can buy a Bolly 20x10 pre-balanced carbon fiberprop from [link=http://www.bollyprops.com/bolcf18-23.html]Bolly[/link] or from [link=http://www.desertaircraft.com/bolly.html]Desert Aircraft[/link]. I don't know how big the prop hole is. However, Bolly can customize the prop to your specifications.
